Help! No Alt Charge No Dash Lights
Old Nov 29, 2015 | 12:08 AM
Verlassene's Avatar
Alright so to make a long story short I recently bought an Evolution VIII and quickly found that the car had battery/alternator issues. The battery is a trunk relocated Optima Red Top.
It had been leaking out of the back so I went ahead and bought a new battery but still was having issues with the car after driving a while (battery and SRS then dead) and found my Alternator went bad as the battery wasn't charging.
Due to having an early bracket design (goes behind idler pulley and back of the head not both back of the head) I couldn't find an alternator that had the correct housing so I paid a local shop to rebuild my OEM.
After the install my Battery and SRS Lights went away so I thought issue had been fixed but the car still runs the battery dead.
I have checked the plug and bolted-on line on the Alternator and the 60 and 100 amp fuses but all seem just fine and I have no lights on dash yet I'm still getting no charge.
What else can I try?
Old Nov 29, 2015 | 12:24 PM
barneyb's Avatar
I know on same cars the alternator will not charge if the dash light for the alternator is burnt out.
Old Dec 1, 2015 | 08:30 AM
Verlassene's Avatar
You may be in to something there. When I put key into ignition and turn forward to test the lights I'm missing a few I think including the Battery Light
Only ones I have are oil and SRS
Old Dec 1, 2015 | 10:25 AM
Verlassene's Avatar
So I pulled the cluster and all the bulbs looked good with the exception of the CEL which was just removed entirely. I swapped the bulbs around and still had the oil light but no battery light or abs (!) light. I have no idea why
Old Dec 1, 2015 | 03:05 PM
barneyb's Avatar
I notice I have bulbs out for headlights and seatbelt. I know from experience that once I pull the cluster and start messing with the bulbs just the shock of touching them will break the old filaments. I need to call the dealer and ask for all the bulbs in the cluster. Otherwise, I will be doing this repair twice.
The bulbs are so tiny I have trouble seeing the filaments. You can ohm them with a meter.
Old Dec 2, 2015 | 09:18 PM
Verlassene's Avatar
The bulbs are good, the ones that didn't light before then lit when put in the oil pressure spot.
Old Dec 7, 2015 | 11:04 PM
Verlassene's Avatar
Any ideas anyone? I still can't solve this
Verlassene
Dec 3, 2015 09:46 PM
jdmevo123
May 1, 2010 03:16 AM
itscypha
Lancer Troubleshooting
Oct 30, 2009 12:34 PM
Sansone
Feb 25, 2009 09:11 PM
