Jun cam idle fix
Old Mar 24, 2004 | 10:49 PM
AMS's Avatar
AMS
Jun cam idle fix
For those running stock ecu's and jun cams here is a little idle fix. Jun cams have quite a bit of overlap (intake and exhaust valve open at the same time) and we can reduce that by retarding the intake cam (opening the intake valve later) and advancing the exhaust (closing the exhaust valve earlier). 2 degrees each(at the cam) is sufficient to smooth out the idle and make it much more driveable. Will it affect horsepower?, not sure on the Jun's but let me tell you that more overlap doesn't mean more horsepower on a turbo car. My guess is that the JUN's already have so much valve overlap that taking 4 degrees out won't hurt horsepower. Hope this helps, any questions?
Martin
Old Mar 24, 2004 | 10:54 PM
ogvw's Avatar
sounds like the wrong cam for your motor..... or a poor cam design
Old Mar 25, 2004 | 12:15 AM
AMS's Avatar
AMS
I'm not running the cam, just something I ran into on another (customers) car.
Old Apr 10, 2004 | 12:17 PM
Shahul X's Avatar
any new news on this?
-shahul
Old Apr 10, 2004 | 08:07 PM
axispowerracing's Avatar
There is also a reflash option from another vendor that I have used and it works flawlessly. Rock solid idle with JUN 272 cams.
Ron
moparfan
Mar 18, 2021 10:28 PM
chaotichoax
Apr 12, 2020 11:55 PM
David Buschur
18
Mar 17, 2012 10:32 PM
TakaseEVOIXSE
Feb 25, 2009 11:33 AM
MR EVO 2410
May 23, 2007 09:10 PM
