Choosing the correct piston for 2.4L 4g64 block
Old Jan 15, 2016 | 09:50 PM
Howulikemyevo's Avatar
Cool Choosing the correct piston for 2.4L 4g64 block
Hi fellow evom members.
I'm builting a 4g64/4g63 head combo on my Evo 8. I just wanted some advice on picking the correct Pistons.
I bought a 4g64 block from a 2001 galant for my built.
I already bought the following for my built:
Manley forge 100mm crank
Manley TT I beam rods 156mm
ACL race bearings
Arp main studs
Fluidamper
GSC r2 camshaft
GSC beehive 5041 spring and titanium retainers
GSC no tick lifters
Kiggly HLA
Aem cam gears
6466 precision turbo
I will be using dual map on pump gas and e85.
I'm looking to used a 9.0:1 compression with a 0.20 over bore. Also with upgrade 200-225mm wrist pins. Hopefully I will be making 600hp on pump gas and 750hp on e85.
If anyone can tell me the parts number and where to get the best prices would be great!!!!
Thanks in advance everyone 👍👍👍👍
Old Jan 15, 2016 | 10:07 PM
hermesevo8's Avatar
Up
Old Jan 16, 2016 | 07:18 AM
kikiturbo's Avatar
http://www.wiseco.com/Catalogs/Sport...Mitsubishi.pdf
page 82
K627M865AP
talk to english racing for parts and exact advice on what to get..
Old Jan 16, 2016 | 07:53 AM
LetsGetThisDone's Avatar
page 82
K627M865AP
That's the right piston, except he need the 87mm one for .020 over in a 4g64 block.
Old Jan 16, 2016 | 11:50 AM
kikiturbo's Avatar
you are right.. I forgot it is 86.5 stock bore..
so, the next piston on the list..
Old Jan 16, 2016 | 12:15 PM
Thanks guys for these advice.
Old Jan 16, 2016 | 12:19 PM
Question
So the K627M87AP is the correct one?
Because I have the Manley 156mm rods and the Manley 100mm crank
Old Jan 16, 2016 | 12:59 PM
kikiturbo's Avatar
yes... that is the g64 piston for 100 mm crank and 156 mm rod.. 9:1 CR and 87 bore..
but i do urge you to talk to someone like english racing, who stock these pistons and get it from them.. prices are ok and you will get the advice you need if you are not sure..
Old Jan 16, 2016 | 01:03 PM
Exactly this. And maybe you can convince them to sell you their 4g64 head gasket too.
Old Jan 16, 2016 | 08:13 PM
Will do.
Appreciate your help!!!!
Thank you
Old Jan 16, 2016 | 08:53 PM
Any other piston that have 9.0:1 compression that I can used?
I know there is a lot of 2.4L 4g64 built here in evom.
Can you tell me about which one you used?
Thanks
Old Jan 17, 2016 | 12:05 AM
kikiturbo's Avatar
manley extreme duty with thick pins 608020CE-4 9.1 CR
CP piston SC7262, but you need to order upgraded pins...
all of this you need to confirm with the builder.. I would go with wiseco HD2 though..
Old Jan 17, 2016 | 12:59 AM
Wiseco HD2 are probably the best. They're a true FSR piston. Idk if the what CP and JE offer for our cars are actual FSR's, or just machined full rounds.
Old Jan 17, 2016 | 01:11 AM
kikiturbo's Avatar
JE doesnt have an off the self piston, custom is an option though..
yeah, Wiseco HD2 looks the best as far as the forging goes..
Funny thing is, those manufacturers that have lots of piston versions usually dont know what they have. I was looking for a wiseco piston to fit 2.0 with long rod but with slightly higher CR.. like 9.2 to 9.4... to run on pump.
Wiseco had nothing for long rod stock stroke but when I looked at E85 pistons for strokers (that have right pin height for long rod 2.0) I noticed that 10.5 CR stroker piston has the right dome CC to end up being a 9.4 (or so) 2.0 long rod piston... hahah.. Ordered those.
Yesterday I was chuffed to find that Wiseco actually introduced my category in the catalogue.. i.e. 2.0 156mm pistons with slightly higher CR.. and hey, there are my pistons..
Old Jan 17, 2016 | 02:06 AM
3gturbo's Avatar
Ross pistons are also a good choice. They will even custom make a set to your specs. Heres what mine look like in my 3g. Yes they are coated also Look how thick the ring lands are on the side
Attached Thumbnails Choosing the correct piston for 2.4L 4g64 block-piston1.jpg   Choosing the correct piston for 2.4L 4g64 block-piston2.jpg
