Tapered Roller bearings For Trans rebuild
Old Jan 26, 2016 | 01:41 PM
EvowagonIX's Avatar
Does anyone know the part number or where to order these bearings. Planning on using them when rebuilding my transmission.
Thanks.
Old Jan 26, 2016 | 01:50 PM
LetsGetThisDone's Avatar
Which ones? there are 4. And the input shaft uses 2 standard ball bearings.
Old Jan 27, 2016 | 03:42 AM
EvowagonIX's Avatar
Input.
Old Jan 27, 2016 | 05:57 AM
You don't want to do that. That portion of the case isn't designed for the loads the taper roller bearings will put on it. Get the regular roller bearings and set the clearance on the loose side of OEM spec.
Old Jan 27, 2016 | 06:20 AM
EvowagonIX's Avatar
I was told the tighter the better? Why the loose side if you don't mind me asking?
Old Jan 27, 2016 | 07:02 AM
Roller bearings don't like thrust, The looser the shaft is (within OEM spec), the less thrust they experience, and the longer they live. This what TRE told me to do when he walked me through assembling my trans. I assemble it per his his instructions and I have not driven an Evo that shifted better at high rpm.
Now, the taper bearings on the output shaft and center diff, those you want to set on the tight side of OEM spec.
Old Jan 27, 2016 | 07:18 AM
EvowagonIX's Avatar
Ok kool, Ill just order the rebuild kit from jacks then.
MuslimEvoFreak
Oct 13, 2012 10:50 AM
cbseven
43
Mar 29, 2012 02:01 AM
J8dailo
Oct 24, 2010 11:11 PM
propellerhead
Mar 7, 2005 08:17 AM
