FP turbos
Old Feb 11, 2016 | 09:04 AM
Nadaevo's Avatar
FP turbos
Curious on how long the FP green-black mhi hold up for? Let's say 30psi
Old Feb 11, 2016 | 09:12 AM
e_kobz's Avatar
Like anything it depends on how its used. being used on the street is different than beating on it for five 20 minute NASA sessions.
Old Feb 11, 2016 | 10:03 AM
LetsGetThisDone's Avatar
the turbo itelf, ie the CHRA, turbine and compressor wheels will hold up fine. The only problem will that the divider in the MHI turbine housing will eventually crack, and then may eventually fail. It will still likely go for quite a long time though.
Also, remember, a green is making more heat to make 30psi than a red, the red more than a black, etc.
What are your power goals?
Old Feb 11, 2016 | 11:08 AM
Nadaevo's Avatar
I'm trying to make around 550whp on e85 most likely going with the black mhi. Dd won't be beating on it too much trying to keep it reliable
Old Feb 11, 2016 | 11:47 AM
Built motor or stock block? A red will make 550 dynojet on E85. A black will be a good bit laggier, but it'll be a little easier (a bit less boost) to make 550.
Old Feb 12, 2016 | 06:27 AM
Nadaevo's Avatar
Built 2.4 so I'm wondering what the lag difference would be.
Old Feb 12, 2016 | 09:44 AM
Probably about 500rpms difference in boost threshold. I would go with the red personally. It will probably make 550tq and 550-600hp. And be an absolute riot to drive with full boost coming below 4000rpm if you get a twin scroll hot side.
evoixmr1818
25
Apr 17, 2010 05:36 AM
Speed Element
58
Apr 18, 2006 05:36 PM
