DIY COP Setup Parts List
Old Feb 23, 2016 | 04:38 AM
soderdna's Avatar
I'm looking at making a cop kit for my evo 9. I was thinking of getting K series ignition coils but after doing some searching on here it seems there are a lot of cheaper options.
What is the best, most cost effective route to go with this. What all do I need to make a working kit. Do I need to run a different spark plug after the fact. Thanks in advance!
Old Feb 23, 2016 | 06:53 AM
IzzyRS's Avatar
The most expensive part should be the coils, so shop around. I ended up with some used K series coils. I ordered the coil connectors from Spoolinup but ended up also finding them on ebay(with a pigtail on them, so that was nice). You also need to order 2 Mitsubishi connectors to hook up to the harness(also from Spoolinup). I made a mounting plate but need to make a sturdier one. The whole project cost me under $100.
Old Feb 23, 2016 | 07:20 AM
soderdna's Avatar
Thanks for the reply sir
Old Feb 23, 2016 | 09:46 AM
IzzyRS's Avatar
You got it. You should be able to open up the gap on your plugs after this mod if you want to. I am very pleased with the outcome, the car seems to run better!
Old Feb 23, 2016 | 10:06 AM
soderdna's Avatar
Did you have to run a different plug? I noticed some people saying you need to run a resistor style spark plug after
Old Feb 23, 2016 | 03:29 PM
egis's Avatar
https://www.evolutionm.net/forums/ev...lug-setup.html
Old Feb 23, 2016 | 08:21 PM
IzzyRS's Avatar
I am running the same plug, same gap, no issues whatsoever. Plugged right into the existing harness, nothing had to be messed with.
llDemonll
Aug 5, 2021 10:07 PM
Ty-tec9.5
Mar 6, 2013 09:27 AM
BRONCO
Jul 13, 2012 11:51 AM
SpoolinUp
Mar 8, 2010 10:22 PM
