Oil pump failure? =/ 9000 miles on 2.4LR build
So on my way out last night when I started my car my engine sounded a little louder than normal and as I was pulling out my oil light came on so I immediately turned the car off. First thing was check the dipstick to make sure I had oil and the dip stick didn't have anything on it except a single streak of oil so I thought for some reason I had no oil, but after going back out after a couple hours the oil level was perfect. I'm assuming that's normal and that the oil drains back into the pan.
I was actually waiting for the next oil change to put in an aem pressure gauge so I thought I'd do it sooner and install the gauge and drain the oil to check it. I bought a new oem oil pressure sender as well just in case. The oil looked fine as I drained it, didn't check the filter.
After I finished everything up I primed it for a few seconds (disconnect crank sensor, etc) then started it. It sounded pretty sluggish immediately so I cut the engine before the aem sensor ever initialized. I'm scared to even start it again.
Nothing really happened before hand. It's winter so I haven't been driving the car hard at all. My belt squeaks occasionally and on friday it was sounding a little odd in how it would come and go but I figured I was just being paranoid. The car on the way home from work also seemed like it was vibrating a little extra right before I got home but again I figured I was just being paranoid.
There is a decent leak coming from the plastic lower timing cover that I've never noticed before.
I don't know, any thoughts? I'm pretty dejected right now and have no idea what to think.
Do oil pumps usually leak from failure? Could the oil leak be causing the pressure issue? I've started taking it apart., just looking to see if anyone has had past experiences/knowledge.
I just needed to replace the front casing which the oil pump is part of (~$230 4G63 new part). I also added a fluidampr to eliminate any harmonics at higher rpm’s as I think that contributed to my pump failure (rev limit ~9700rpm).
This is the part I replaced.
http://www.streettunedmotorsports.co...e_oil_pump.htm
I don't think either of those are the case. I know the second one isn't because I worked on the engine and as for the first I'm using Signature Series 5W-50 for the colder months and it wasn't very cold anyway.
I might have exaggerated. I checked it immediately (ie within seconds) of turning the car off at first and there was oil on the dipstick but not a normal "line" indicating level. I then checked again about 5 or 10 minutes later and it showed slightly less than the low mark on the dipstick and then when I checked later it was the normal level, maybe slightly less on account of the leak.
