o-ring head and block?
Old Mar 6, 2016 | 02:43 PM
saxon's Avatar
have a little dilemna that i was hoping to get an answer to
i currently have an evo 8 with built head, built trans and TC. i want to max out my fp red without worries of managing the tq.
i found a used bare bottom end that was bored .20 over, when i finally got a chance to clean it i noticed that it was o-ringed. normally this would be great, however i have a buschur stage 3 head which is also o-ringed. is it possible to run an o-ringed head and block together?
thanks
Edit: from the research I've done , I could have the block decked with the copper o-rings in it and that would work
Old Mar 6, 2016 | 03:23 PM
roni4g63's Avatar
this is what Tom at Tscomptuned stated on a post where the member had a 2.3 liter build block and it was o-ringed.
"I don't see why it wouldn't. it will just crush the MLS gasket on both sides with a different set of o-rings. Id do more research on it though first before you go ahead and do it. The BR head uses a steel oring, this block has a copper oring."
link to that post:
https://www.evolutionm.net/forums/sa...l#post11583667
goodluck brother
Old Mar 6, 2016 | 03:42 PM
3gturbo's Avatar
link to that post:
goodluck brother
bad idea to mix 2 dissimilar metals it will have a chemical reaction.
Old Mar 6, 2016 | 04:52 PM
saxon's Avatar
there is a headgasket in between the two
Old Mar 6, 2016 | 05:01 PM
roni4g63's Avatar
so is the head and the block, but the headgasket provides a surface for the dissimilar metals to expand on with different rates, I think he would be okay honestly, best thing to do it call an experienced machinist and ask.
Old Mar 6, 2016 | 06:45 PM
detroit pistins's Avatar
The two rings would need exactly on top of each other in order to reduce the potential of having uneven clamping force. You can verify the radius from the center of the to each ring but you will need to be very precise with your measurements.
on a side note, are you planning on decking one of them to ensure at least one is flat? if so, then remove that one ring!
Old Mar 6, 2016 | 07:08 PM
saxon's Avatar
i could get the head or block decked, how deep are the rings and would getting it decked take off enough that i wouldnt need to have an o-ring?
Old Mar 6, 2016 | 07:41 PM
The machinist should be able to measure the depth and decide how much material to remove.
Old May 30, 2016 | 06:32 PM
roni4g63's Avatar
any updates on this?
5LEEPERISAH23I
31
Nov 20, 2013 08:39 PM
L888Apex
10
Jun 25, 2011 10:12 AM
TheLab
Aug 17, 2007 06:01 AM
