Anyone using the TRE 5 speed transmission adapter plate
Old Mar 10, 2016 | 05:00 PM
flyingscot's Avatar
Hi all,anyone using the adapter plate for the 5 speed transmission made by TRE,anyone using it for a cooler specifically?
Old Mar 10, 2016 | 06:37 PM
LetsGetThisDone's Avatar
I have it on my car. No cooler hooked up. The oring it comes with leaks, save yourself time and just us silicone like the stock piece.
Old Mar 10, 2016 | 08:02 PM
flyingscot's Avatar
Thanks for the tip,leaks drive me nuts too
Old Mar 11, 2016 | 11:24 AM
heel2toe's Avatar
I've got both the trans piece as well as xcase and maybe I just got lucky but neither of mine leak.
No trans cooler here either but the main trickery behind this piece is the way it deflects oil onto 4th gear so its constantly getting fresh oil thrown on it which helps to keep it cool. Adding a trans cooler on top of that would only help even more.
Old Mar 14, 2016 | 08:01 PM
flyingscot's Avatar
Thanks yeah i was wondering specifically how to route my plumbing,it seems id want to feed my pump from the drain plug but I'm not sure if i want to pull fluid from the TRE plate too and return to the TRE plate and the fill hole on the tranny,just seems like plumbing overkill although i personally think the tranny cooler is a must on a track car
Old Mar 14, 2016 | 09:48 PM
The cooling plate has an in and an out port, they're 3/8 NPT. You can plumb both of your cooler lines to it.
antilag_200
74
Sep 19, 2016 01:54 PM
CO_VR4
12
Apr 9, 2010 10:19 AM
CO_VR4
44
Nov 6, 2007 10:57 AM
sterdyevo
Oct 13, 2007 04:54 PM
SuperHatch
24
May 15, 2006 05:09 AM
