Stock Evo With Atmospheric BOV
Old Mar 16, 2016 | 05:22 PM
boostislife's Avatar
Hi, I bought a Evo 8 recently and it's all stock besides an atmospheric BOV (unknown brand) would this cause poor idling? My idling is pretty bad at times, the rpms drop really low then they'll rise up quite a bit. Would it be because of the BOV or would something else be causing this?
Old Mar 16, 2016 | 05:38 PM
asu11's Avatar
Could be the bov, but could be other things such as a boost leak or the tune.
I ran a VTA bov with MAF and stock IC piping for a while with no issues.
Old Mar 16, 2016 | 05:43 PM
Bhsj13's Avatar
just recirc it.
Old Mar 17, 2016 | 09:50 AM
austin46's Avatar
If the BOV has a spring in it light enough that it hangs open a little bit at idle, then yeah it'll cause it to run poorly as long as it's open loop.
Like the guy above said, just recirculate it. You won't gain anything going VTA stock, and it'll run worse.
Old Mar 17, 2016 | 09:59 AM
LetsGetThisDone's Avatar
Lightly sprung BOV's are open at idle. You need to recirculate it. Your car is on MAF, so your dumping metered air out of the BOV and confusing the ECU. Either get a speed density tune, or recirculate the BOV.
Old Mar 21, 2016 | 06:20 PM
couple of nooby questions.
1. Could this also cause the service vehicle soon light to be on?
2. How would I go about recirculating the BOV? Or would I be better off going back to a stock 8 BOV or getting an Evo 9 BOV?
Old Mar 21, 2016 | 06:41 PM
Denzi_92's Avatar
what if Im running speed density? would a atmospheric dump be ok? could I do 50/50? (don’t like too much noise) or keep it recirculating?
sorry not to highjack thread, cant post new threads yet.
Old Mar 21, 2016 | 09:12 PM
rage mang's Avatar
my answers to questions
1.it possibly could, the venting of air messes with the maf sensor.
2.if your bov has a connector or adapter that can convert it to a recirculating type then go for that my old gfb bov had a trumpet block adapter if i wanted it to fully recirculate. on that note i would suggest going back to stock or getting a metal evo9 valve as those will handle any horsepower you throw at it unless you get a little crazy and the driveability benefits of the stock piece really outweigh all the vent to atmosphere choices.
Old Mar 22, 2016 | 08:40 AM
Thank you! Much appreciated. Any recommendations on what site to order a metal 9 BOV off of?
Old Mar 22, 2016 | 08:44 AM
http://www.maperformance.com/products/oem-evo-mr-blow-off-valve-mitsubishi-lancer-evo-8-9?utm_source=googleshopping&utm_medium=cse&gclid=C Ib5suvQ1MsCFdgRgQod_5gEkA Is this the one you're talking about?
Old Mar 22, 2016 | 10:45 AM
rage mang's Avatar
yea go for that one but i do regularly see them on sale here in the forum if you dont wanna pay that
BlackOperative
Apr 6, 2012 09:38 AM
Noogie
Jan 8, 2009 10:59 PM
highhats
Sep 3, 2008 08:59 PM
XxMr.Evo.xX
Jun 11, 2004 02:10 PM
