NEED HELP!! boost issues and more
Old Mar 21, 2016 | 04:24 PM
jb0evo's Avatar
Originally Posted by kaj
yep, you can install a MBC, EBC, or aftermarket solenoid and do ECU-based boost control. It costs more, but you can control the boost.
I have a Grimmspeed solenoid and using the ECU to control boost.
Okay so then u definately dont need those lines once you get a EBC like a Grimmspeed?
If so ill just buy one of those, was eventually the plan anyways.
But i might also consider the offer on those stock lines that way i can put those on and
see if that is actually causing my problem
Old Mar 21, 2016 | 05:39 PM
kaj's Avatar
kaj
Correct, you just use standard vacuum lines, no restricter needed. Let me know if you need it. I can send it out any day besides Thurs/Fri
Old Mar 21, 2016 | 06:51 PM
3gturbo's Avatar
Turning up boost without supporting mods and a tune is not a good idea.
Old Mar 22, 2016 | 05:08 AM
jb0evo's Avatar
Right, but setting it at the correct boost and it being even more stable than
stock lines would be better.
Old Mar 22, 2016 | 10:01 AM
kaj's Avatar
kaj
I'm not sure there is anything more stable than stock. Mitsu was pretty good about keeping their cars from blowing up
phenem
Oct 11, 2008 08:47 PM
BeefyEvo
21
May 10, 2006 01:19 PM
Kwman
21
Jul 14, 2005 07:34 AM
