Front o2 code comes back on after new o2 instal. Need help.
Old Mar 26, 2016 | 12:50 PM
2006GSR's Avatar
Hey guys.
Car runs like poo from 1-2k rpm then runs decent. Throws Code p0134 for Heated oxygen sensor front circuit no activity detected even after we put a new denso o2 in. Clear the code and it comes back within roughly 5 miles of driving. Sometimes within 5 min of just idling.
What would cause it to do this?
Thanks
Old Mar 26, 2016 | 01:08 PM
06RedRalli's Avatar
Possibly a silly suggestion, but you disconnected the battery for a bit correct after the new o2 sensor install?
Old Mar 26, 2016 | 01:21 PM
2006GSR's Avatar
Battery got disconected for a few minutes.
Old Mar 26, 2016 | 01:28 PM
06RedRalli's Avatar
Was the sensor a splice in, or plug in?
Old Mar 26, 2016 | 01:47 PM
2006GSR's Avatar
Plug in.
Old Mar 26, 2016 | 05:54 PM
evo.matt's Avatar
my car throws the same code, but hasn't affected its driveability. At this point I think the connection from the plug to the ecu is damaged and needs to be rewired.
Old Mar 26, 2016 | 05:58 PM
roni4g63's Avatar
car runs sluggish check plugs and coils
Old Mar 26, 2016 | 06:49 PM
2006GSR's Avatar
New plugs and tried friends oem coils of his car that is making 770 and same thing.
Old Mar 26, 2016 | 08:40 PM
2006GSR's Avatar
Would an exhaust leak cause this?
Old Mar 26, 2016 | 08:42 PM
roni4g63's Avatar
yes it indeed can, any exhaust leak before the 1st sensor can throw a code.
Old Mar 26, 2016 | 08:56 PM
2006GSR's Avatar
Might of figured out the problem. Thanks ill report back. It has a leak right of the turbo from the external dump.
Old Mar 27, 2016 | 03:46 AM
roni4g63's Avatar
did you find your problem?
Old Mar 28, 2016 | 06:10 PM
2006GSR's Avatar
Nope. Starting to think its tune related.
Old Mar 28, 2016 | 07:05 PM
2006GSR's Avatar
Got a leaner base map from my tuner. Car runs way better but same code comes back on working 5 min of driving the car. Bought a brand new denso front o2 sensor aswell.
Any one got any ideas where to look?
Old Mar 29, 2016 | 04:43 AM
XSivPSI's Avatar
I got this code after following directions on here for disabling the rear o2 sensor, and it ran poorly at low rpm. I just reversed what I did and deal with the rear o2 cel so it at least runs right.
Also, why is your tuner giving you base maps? Shouldn't he be tuning it?
