Need help!! Cam install problem
Old Apr 21, 2016 | 10:32 PM
shiftdown5's Avatar
Exclamation Need help!! Cam install problem
I'm installing some GSC S1 cams into my car. I have them pretty much in there. My problem is the 12mm bolt I took out of the CAS is too small for the GSC cams. Was I supposed to get something else from GSC to make these work? The tread pitch in the new exhaust cam is a 17mm instead of the 12mm that came stock. You can see my factory pick up for the cas has a 12mm bolt hole in it. And the end of the cam in the lower picture has a 17mm bolt hole :[
Old Apr 25, 2016 | 08:47 PM
kpr's Avatar
kpr
No , should be a drop in install. Maybe check the part number on the cam and be sure its not a Evo 9 intake camshaft.
Old Apr 27, 2016 | 02:25 PM
shiftdown5's Avatar
I managed to figure it out. The pickup in my cam sensor needed to be bored out to the larger 12mm bolt diameter and I picked up a nice grade 8 allen head bolt to use with it. After that it worked perfect!
RKT SHP
13
Sep 1, 2005 01:46 PM
TammieNAndi
Midwest Region
Jun 22, 2005 02:13 PM
krafty
Southeast Region
May 22, 2005 05:50 PM
nirvevo
Turbotrix Racing - Edison, NJ
Oct 3, 2004 06:11 PM
hardcoretuner
Aug 9, 2004 10:03 PM
