evo 9 turbo shaft play up and down
Old Apr 28, 2016 | 09:42 PM
zbestevors's Avatar
i bought a used evo 9 turbo that had 150k miles on it.it has more up and down play than my evo 8 turbo That has 86k. Im going to rebuild it myself. Do any one know if Putting in new bearings eliminate some of the up and down movement. There is no contact with the compressor housing.
Old Apr 28, 2016 | 10:04 PM
LetsGetThisDone's Avatar
Depends on the amount of movement. The real movement to be concerned about is if he shaft moves in/out. That's thrust bearing wear, and typically that's the first issue that arises.
Old Apr 28, 2016 | 10:27 PM
zbestevors's Avatar
ok thanks. in and out play is good. I read that the oil pressure floats/centers the shaft. ill just rebuild it do to high miles and update this post after.
Old Apr 28, 2016 | 10:39 PM
Yes, oil takes the space up for the up/down play whenever car is running.
irmerm
13
May 13, 2011 10:06 PM
ch1215g
11
Mar 23, 2011 05:35 PM
-Evo Aaron-
Dec 28, 2010 09:12 AM
tiffsevo
Feb 18, 2010 08:42 AM
Solo II Evo
Sep 19, 2008 05:42 PM
