MBC problem?
Old Mar 28, 2004 | 04:27 PM
evolife04's Avatar
MBC problem?
not sure what's going on with my Halman MBC i set it to run 19 psi but im only getting 16psi in 1st and 2nd gear then i get 19psi in 3rd gear. is this normal?
does anyone have any input? oh btw i have the Halman pro.
i have it hooked up correctly and all vacum lines are tight
thanks for the help
Old Mar 28, 2004 | 05:10 PM
mhgsx's Avatar
That's pretty normal.
Since the gearing of 1 and 2 is so low, you're not able to put enough load on the engine for the boost to reach your preset.
Old Mar 28, 2004 | 05:15 PM
EVOVIIIU's Avatar
Turn that **** up man!!!! hehe
Old Mar 28, 2004 | 10:04 PM
evolife04's Avatar
i would turn it up but then i would be over boosting in the other gears... hmm not sure what to do..
