Valves!
Old May 21, 2016 | 02:36 PM
Ckeesee12's Avatar
Valves!
Last year my car decided to throw a rod and destroy a piston. I'm just now getting around to fixing it. My questions.
More than likely, from have a few buddies look and myself we are assuming it bent the 2 intake valves on cylinder 1.
What all will need replaced?
2 valves, a set of locks for each, and a seal for each? I'm going to have a shop look and tell me, but I don't wanna get dicked around either.
Thanks in advance
Old May 21, 2016 | 05:19 PM
CurseDSM's Avatar
2 valves, seals, have the machine shop reseat the valve, thats about it you don't need locks unless you lost them locks don't go bad. Oh and of course any damage that was done to the bowl of your head. If there isn't any damage then sweet but thats pretty much it
Old May 22, 2016 | 01:54 AM
kikiturbo's Avatar
chances are you will need to change the guides too.. if you are still on oe guides
Old May 22, 2016 | 11:09 AM
CurseDSM's Avatar
Depends on how hard the valves got wacked. Most times you should be ok but good call.
Old May 22, 2016 | 11:18 AM
kikiturbo's Avatar
since it was a broken rod, chances are the valves didnt get hit hard.. so guides should be ok... but check them anyway.
Old May 22, 2016 | 02:26 PM
CurseDSM's Avatar
Yeah good point. If the guides are cracked you would notice them with a flashlight inside the valve area. You will see the cracked area if it is at all. Obviously valves have to be out of the head. Good luck with it.
Old May 23, 2016 | 11:57 AM
Ckeesee12's Avatar
Thanks everyone!
itsdecker
13
Oct 1, 2016 07:14 PM
RedEvo6
41
Sep 1, 2011 12:16 PM
tupac1
Dec 11, 2009 07:04 PM
Anarchy99
May 9, 2006 08:08 AM
Guack007
Nov 14, 2002 05:50 AM
