What is the best spark plugs for different setup
Old Jun 12, 2016 | 01:37 PM
Howulikemyevo's Avatar
Hi. I wanted to know what is everyone using and recommend for different setup.
I'm currently have a Evo 8 with built 2.4L block and 4g63 built head.
Please put your input on what brand and parts # please!
Old Jun 12, 2016 | 10:25 PM
evillancer06's Avatar
Veteran: Navy
You do realize that there are about 50 billion posts on spark plugs alone. Have you tried searching at all?
Old Jun 13, 2016 | 04:27 AM
ctfpevoVIII's Avatar
Do you tune your car yourself or are you having it tuned by someone else? If by someone else , ask them what plug they prefer for your setup.
Old Jun 13, 2016 | 09:29 AM
I'm just curious on what people used on the Evo 8 & 9
I wanted to know what is working for them. Also please tell me what is your gap size that you set on your plugs.
Thanks
Old Jun 15, 2016 | 10:16 PM
Erik@MIL.SPEC's Avatar
FYI, the Evo 8 and 9 use different plugs.
Old Jun 16, 2016 | 05:40 AM
For Evo 8 with 2.4 stroker
Old Jun 16, 2016 | 08:10 AM
heel2toe's Avatar
Block doesnt matter its the head that you need to go by. If you're using an VIII head then you need plugs that work on an VIII and Mivec head would be plugs that work on a IX. There are countless threads on this so I'd recommend searching given what head you plan to use. Personally I prefer the iridiums vs coppers and have had good luck with BPR7EIX but depending on power fuel boost etc will change what plugs will work best for you.
Old Jun 16, 2016 | 08:22 PM
Thanks for your info.
This is the kinds of input I want to know from each person.
Old Jul 13, 2016 | 07:11 PM
TrendSetter's Avatar
different boost, fuel and confidence dictates different plugs
cudaman07
Jun 23, 2015 11:41 AM
ktk
18
Mar 27, 2009 02:43 PM
johnsevo9
34
Jun 21, 2008 09:46 AM
Import Junky
90
May 13, 2008 12:58 PM
kikiboi
12
Jul 6, 2007 12:49 PM
