Evo 9 coil pack retune?
Old Jun 15, 2016 | 07:05 PM
Logan Fang's Avatar
Hi guys
Recently i bought a sparktech non-cdi coil pack to replace the oem one. After it installed the idle seems a little bit high at around 1300rpm. Have searched few times but did not find answer. Wondering do i need to get it retune just for the new coil pack.
Thanks for help.
Old Jun 15, 2016 | 09:56 PM
LetsGetThisDone's Avatar
The tuner should be able to look at that and fix it. It either needs less timing at idle, or an adjustment to the BISS. It doesn't need a whole retune.
Old Jun 16, 2016 | 07:18 AM
llDemonll's Avatar
Coil pack won't require any sort of retune. No reason the car should be idling higher just because of that COP
Old Jun 17, 2016 | 07:36 AM
It depends. If the old coils were tired, the tuner may have cranked up the timing in the idle area of the timing table to stabilize the idle, which could cause a high idle once a better set of coils was installed.
Old Jun 18, 2016 | 05:45 PM
Logan Fang's Avatar
Problem solved. After i got a new tank of gas which is 94 octane just like the previous i used and from same gas station, idle just back to normal.
Old Jun 18, 2016 | 06:39 PM
Bhsj13's Avatar
we all have bad gas sometimes.
Rossi_24
May 21, 2016 09:09 AM
Thugline
Aug 11, 2010 01:55 PM
Gruppe-S
40
Feb 28, 2007 02:01 PM
Gruppe-S
Jan 17, 2007 09:40 PM
