Head repairable??
Old Jun 30, 2016 | 05:56 PM
barneyb's Avatar
Originally Posted by meckert
No compression = blown head gasket, bent valves and or bad rings....or all of the above. Kinda looks like it ate something. Have it magnafluxed and valves check for seal--then determine what you want to do about the combustion chamber.
Yes, and what damage did the cylinder and piston incur? Did you find the washer in the damaged cylinder?
Old Jul 1, 2016 | 06:30 AM
EvO_essence's Avatar
The cylinder has a scratch in it, so it will need bored. The piston has completely rolled over valve reliefs. But the piece was in the stock turbo luckily so it didnt go past the rings.
the entire build only got 75 miles before it was noticed.
Old Jul 1, 2016 | 07:20 AM
meckert's Avatar
Crank should be fine-- Good luck on the rebuild.
Old Jul 1, 2016 | 09:54 AM
barneyb's Avatar
A heart breaker!!!
Old Jul 2, 2016 | 07:43 AM
Originally Posted by barneyb
A heart breaker!!!
Very much so. But its on the stand again and will be back and going soon. Its a lesson learned to make sure "professional assembly" was done right.
Old Jul 12, 2016 | 09:42 AM
LetsGetThisDone's Avatar
Just so you can see that's it doable. Probably not worth the expense on a stock head. But if you have $2500 into a CNC port job, this would be worth it...
midnightsuns
Feb 19, 2007 03:39 PM
Spins4
Aug 2, 2006 08:26 AM
Jeff_Jeske
Mar 13, 2006 03:09 PM
DizeLLx
23
Nov 12, 2004 09:47 PM
