AFC vs DynoFlash
Originally posted by ruthless evo 8
Also does anyone know if a UTEC or ECU+ unit can be run off a DVD screen instead of a palm or pc? I happen to have such a unit that is touch screen and would be a interesting set up.
I kinda doubt it, tho.
Tom
There are in-car DIN-mount PC's now. I'm not too knowledgeable about in-car DVD screens, though. Can they take a VGA input from a PC? That would be hella cool!
--Dan
Mach V
MachEVO.com
--Dan
Mach V
MachEVO.com
Originally posted by TurbotrixRacing
eric ..
yah i know what you saying. We're talking with turboxs now..see what they say. The value you enter as a timing value should be that timing value. The second car we did, We made his secondary timing map the same, and it was alot easier for junior to tune ... We'll see
mark
turbotrix
eric ..
mark
turbotrix
Mark,
The value in the UTEC's timing map is the value you are running no matter what the stock ECU ignition timing map is doing. Junior explained that he did see some fuel map switching (after detonation) and that was causing him a little frustration.
In any case the timing values in the UTEC are absolute; they are not piggybacked in any way, so it doesn't matter if the stock ECU wants to run 1 degree or 30. The UTEC will always run what you have programmed.
The fuel map on the other hand is still a piggyback system and when the stock ECU switches to a rich or lean fuel map the overall AFR will drift with it.
The new UTEC software addresses this because it is no longer piggybacking off of the stock ECU's fuel map.
I can see a benefit to making the stock ECU’s fuel maps the same (or very close to the same) when tuning with a UTEC, but there would be no benefit to changing the ignition timing maps under full load when the UTEC is in control.
-Nathan
www.turboxs.com
