New build and oil oil on pistons
Old Aug 14, 2016 | 09:45 AM
EVO 4 life's Avatar
I just completed a new buschur 2.3 build and am burning alot of oil and have visual oil on top of pistons. The head was also completely new from very reputable shop. I checked compression and was 180 roughly on all 4.( I'm also at 6000 feet of altitude) I also performed a leak down test and was 5% across the board. I don't see anything obviously wrong with the valve seals. If anybody has any ideas it would be appreciated
Old Aug 14, 2016 | 12:26 PM
LetsGetThisDone's Avatar
Is it smoking?
Old Aug 14, 2016 | 01:34 PM
EVO 4 life's Avatar
Is it smoking?
Yes especially on cold start up
Old Aug 14, 2016 | 03:54 PM
barneyb's Avatar
Sounds like valve seals.
Old Aug 14, 2016 | 04:40 PM
TheBoz's Avatar
There was a thread on here from someone that had a buschur motor that did the same thing. If I remember correctly the rings were not installed correctly. This was about 2 years ago.
If I remember correctly, he had good compression and good leak down, but it was an issue with teh bottom/oil rings and it was letting oil get past where the pin was. The 2.3 has a high piston pin offset.
Old Aug 15, 2016 | 09:56 AM
Here is the thread I think you're talking about. It was an issue with the oil rings like you said. Page 8 is where he posted that he figured it out.
https://www.evolutionm.net/forums/ev...pistons-8.html
Old Aug 15, 2016 | 07:04 PM
EVO 4 life's Avatar
Thanks, I'm going to pull the pistons and see what we have
EvolutionIXMR06
118
Oct 27, 2015 01:52 PM
DormantBeast
18
Jan 30, 2013 05:23 AM
kouzman
Jan 31, 2010 05:46 AM
Gruppe-S
Jul 26, 2005 12:24 AM
