misfire
Old Nov 11, 2016 | 01:39 PM
mrhussain's Avatar
may be a fuel cut, anyone know how to get rid of this?
Old Nov 11, 2016 | 07:51 PM
RightSaid fred's Avatar
Running with the AFR too rich causes misfires.
Need to measure fuel pressure first (only because everyone gets it wrong), then measure AFR under load.
Old Nov 12, 2016 | 06:11 AM
mrhussain's Avatar
i do not have an afr installed yet,
my guess is its over boosting as it seem the previous owner had a boost controller fitted in and then decided to pull it out before the sale as the hoses appear to be after market.
im now riding on the belief that my issue is indeed a fuel cut.
Old Nov 12, 2016 | 11:13 AM
barneyb's Avatar
If you get a p0300 but no identification as to what cylinder chances are the engine isn't misfiring. The car has a lot of vibration coming back from the drive train, often enough to change the engine speed sufficiently to set a CEL. The early 8's contained a subroutine that would shut off fuel to one after another cylinders as it searched for the offending cylinder. This would be the stumble you feel.
I'm not going to detail the fix but it amounts to removing this test from the ECU.
Edit: Please be advised, ordinarily the problem I've described occurs in cruise at around 3000 rpm, not at WOT.
Old Nov 17, 2016 | 07:09 AM
mrhussain's Avatar
my problem is at WOT cruising the car is as good as gold.
Old Nov 17, 2016 | 07:10 AM
mrhussain's Avatar
definitely hitting fuel cut as it has a few Bolt-ons and no tune that effect this
Old Nov 28, 2016 | 02:54 AM
mrhussain's Avatar
good morning my evoM homies, i have officially fixed my missfire/fuel cut by installing a hks evc-s boost controller, the boost is now set at 1.5 bar and holds boost through out he rev range all the way to redline.
this is the first time ive actually had the pleasure of enjoying my evo since i bought it and it is phenomenal, car is insane, i love awd boost.
Old Feb 16, 2017 | 07:54 AM
Tommyfacekicker's Avatar
I'm having similar issues too, won't hit full boost or target boost, gets a rapid machine gun type misfire at wot. Gonna clean my injectors tips bec of the e85 goo n see what happens. I'll update.
Old Feb 16, 2017 | 08:00 AM
mrhussain's Avatar
check your boost solenoid located under the airfilter, i replaced mine with hks and problem still fixed till this day, from this rapid missfire im boosting 2 bar boostall day long for the past months
Old Feb 16, 2017 | 08:01 AM
mrhussain's Avatar
with everyday driving and boosting
johnashton11
11
Sep 13, 2019 01:23 PM
Optimus
Lancer Troubleshooting
Nov 4, 2003 08:59 PM
Stinkapuss
10
Sep 25, 2003 09:35 AM
