Rocker arms fell off!
Old Nov 26, 2016 | 09:39 PM
barneyb's Avatar
I made a thousand mile trip for Thanksgiving too. Anyway, I hope the carnage is not too bad. Good luck.
Old Nov 26, 2016 | 09:42 PM
Hartless93's Avatar
Good thing I already emotionally prepared myself for building the top end haha
Old Nov 26, 2016 | 09:52 PM
Pal215's Avatar
It won't be so bad. It's a great learning experience and a chance to install a new head gasket, better head studs, and get a built cylinder head!
-pal215
Old Nov 26, 2016 | 09:59 PM
Hartless93's Avatar
No doubt! I've been eyeballing a set of GSC S2 cams and +1 valves anyway
Old Nov 27, 2016 | 02:10 AM
kikiturbo's Avatar
stay with stock valve size. get new bronze valve guides and you might need a couple of rockers too.. check for cracks..
Old Nov 27, 2016 | 08:06 PM
barneyb's Avatar
I know the damage is done but still I'm curious as to what happened. So, hoping for a report.
Old Nov 27, 2016 | 08:10 PM
Hartless93's Avatar
Hopefully I'll get a chance to pull the head tomorrow, if so I'll give an update
Old Nov 28, 2016 | 10:59 AM
Facepuke's Avatar
I can say, I have never seen this happen on any car! that is crazy.
Old Nov 28, 2016 | 11:09 AM
Tuxevo's Avatar
If you didn't properly adjust the timing belt tensioner when you performed the service it's probable that you jumped timing and had some P to V contact (not the good kind).
Old Nov 28, 2016 | 12:24 PM
heel2toe's Avatar
Bummer sorry to hear about that. Did you replace the tensioner as well when you did the timing belt service? And did you perform the service yourself or have a shop do it? If you did it yourself did you confirm that you can easily slide the grenade pin in and out to ensure proper tension?
My thoughts exactly. And lol thanks for the laugh as I struggle to get through the day here
Old Nov 29, 2016 | 12:31 AM
kikiturbo's Avatar
not uncommon..
happened to me when the aux belt broke
can happen when you do not change the balance belt
or dont change the tensioner
or just do not tension everything correctly.. or overtension it..
Old Nov 29, 2016 | 05:32 PM
Slow_Supra's Avatar
I recently had this happen to me and it trashed head and pistons. valves bent/broke and smash into the spark plugs. 3/4 pistons done.
Old Nov 29, 2016 | 08:19 PM
Hartless93's Avatar
[QUOTE=heel2toe;11687130]Bummer sorry to hear about that. Did you replace the tensioner as well when you did the timing belt service? And did you perform the service yourself or have a shop do it? If you did it yourself did you confirm that you can easily slide the grenade pin in and out to ensure proper tension?
When I did the timing belt I replaced the tensioner as well as all other pulleys and water pump. I did it at the shop I work at, the grenade pin slid in and out really easy. I pulled #2 spark plug and it was all crushed in and the piston had 2 nasty holes in it so I've now just decided to pull the whole engine, when I pulled off the exhaust manifold and turbo I heard some rattling which ended up being 4 crushed valve faces. There was most definitely some unwanted P to V contact
Old Nov 29, 2016 | 08:25 PM
Hartless93's Avatar
https://www.evolutionm.net/forums/at...1&d=1480479765
Old Nov 30, 2016 | 12:13 AM
kikiturbo's Avatar
uff, sorry to see that... getting more expensive...
