How much life my exedy twin has?
The clutch material is determined by thickness. Measure it.
your floating and the rest looks rough. I would not reuse them without machining them. Then you still have to check for thickness again to make sure they are in spec.
those frictions look great. you can machine your flywheel legs down the thickness of the worn off material. it will then give like new lifespan. I have done this with great results.
measure the disc thickness. new they are 3.9mm each. example if they measure 3.6 and 3.7 you would remove .5mm from pressure plate stands. any clutch shop can remove the thickness on their surface grinder.
Illrunya
Jun 14, 2015 08:10 PM
FS[Northeast]: Exedy Twin Disk HD guys! BNIB Exedy HD Twin Disk REBUILD KIT
Illrunya
Northeast Region
Jun 9, 2015 12:56 PM
Aby@MIL.SPEC
Nov 5, 2014 02:38 PM
Inprogress
20
Jan 31, 2009 01:36 PM
Gruppe-S
Evo 'For Sale' Engine Internals and Drivetrain
Jul 2, 2007 02:08 PM
