Coolant overflow/air pockets/ bleeding
Old Dec 30, 2016 | 01:58 PM
chassis87's Avatar
Dear all,
i fitted a mishi half rad. Which meant i drained the whole system from water.
however the fan is not cutting off.
should i put coolant in overflow tank?
how do i remove air pockets?
Any procedure how to bleed system?
thank you
Old Dec 30, 2016 | 04:09 PM
LetsGetThisDone's Avatar
Let it cool back off, take the radiator cap off and top it off...
Old Dec 30, 2016 | 04:26 PM
Abacus's Avatar
I've had good luck using these to get rid of air pockets
https://images-na.ssl-images-amazon....TL._SX300_.jpg
http://www.rs25.com/forums/f190/t116...nt-system.html
Turn the heater on high and run the car for 5-10 min with the funnel in place. Watch temp gauge, then put cap on.
donperry
May 19, 2016 06:48 PM
sna08
21
Mar 26, 2012 10:32 PM
