Exedy Twin Disc Adjustment
I purchased my evo 9 with an Exedy Twin Disc in it. I heard they're supposed to rattle ad idle and when engaged however mine is silent. I was wondering what i can do to adjust it to its normal self. Thanks
How sure are you the car has an exedy twin? I would suggest you jack her up and look through the inspection hole, to see if there is an exedy twin is in there. If that checks out, then while she is still jacked up, put it in 1st gear and hold the clutch all the way, give it a few revs and see if the clutch is properly disengaging. If it is, then there is nothing to worry about it.
The clutch should be quiet when engaged at idle. The only get noise when disengaged and the plates are bouncing around in the basket.
The engagement issue could mean it's worn out and needs new disks, or the plates are hanging up on the basket towers, and the basket towers need to be polished.
prilianad12
Dec 30, 2013 04:42 AM
bruce988jl
11
May 8, 2013 01:23 PM
subrwho
23
Jun 25, 2010 03:38 AM
Evokid03
Sep 22, 2009 02:19 PM
