Evo 9 turbo
Old Mar 15, 2017 | 06:48 PM
Casey118's Avatar
Evo 9 turbo
Hello I have a 2004 evo 8 I'm in the market for a new turbo and was curious if it's worth going with a evo 9 turbo current things done are tomei exhaust manifold with heat shield, tomei bov, tomei cam gears, injen intercooler piping, muffler delete with 3" exhaust, has cams but not sure what they are, spark tech coil on plug. Stock injectors. The car will need tuned once I get a new turbo that's why I figure I'd just got with evo 9 turbo. Will my stock injectors be enought for a evo 9 turbo.
Old Mar 15, 2017 | 07:06 PM
4G63_EVO's Avatar
Id def recommend the 9 turbo as a budget turbo, Ive dont an 8 with stock injectors and 9 turbo and maxed them out, made 314/320. I would get bigger injectors and you for sure need a bigger pump. If you have the cash and dont mind waiting id send it in and get it built. I sent in my 9 turbo and got a 20G upgrade. Made 430! Lmk if you have any questions
Old Mar 15, 2017 | 08:10 PM
Casey118's Avatar
Car has Walbro fuel pump forgot to put that as well. Just looking to throw it in and get it tuned not going for big power.
Old Mar 16, 2017 | 03:13 PM
tbaird58's Avatar
your stock injectors will be fine, and if your not looking to make huge gains then yeah by all means get the 9 turbo, but your going to need to get an evo 9 j pipe and lines since the 8s are different lengths.
Old Mar 16, 2017 | 04:07 PM
deremer71's Avatar
Is that the biggest you can upgrade a 9 turbo?
Old Mar 16, 2017 | 04:08 PM
deremer71's Avatar
Might do this In the near future also. Is that all that's needed to convert over to a 9?
Old Mar 17, 2017 | 01:43 PM
4G63_EVO's Avatar
No, I do believe I had more room, I got it done from ruben at socalporting
Old Mar 17, 2017 | 03:43 PM
deremer71's Avatar
I Gotcha. Thanks for the info.
Old Mar 17, 2017 | 03:50 PM
deylag's Avatar
You don't need the tomei exhaust manifold, and cam gears. The stock exhaust manifold can do the job. The stock injectors are going to limit you power wise.
I would recommend getting ID 1000s and an AFR gauge. On 91 you could make 360. 400+ on E85.
Old Mar 20, 2017 | 07:33 PM
HawkinCrazy's Avatar
Yeah I make 410hp on E85 at 29psi on stock 9 turbo
Deano_Engineer_
Mar 6, 2014 05:57 AM
WarpFactorVIII
39
Feb 21, 2008 10:12 AM
_EVOlved_
Jul 19, 2007 10:29 AM
Zeus
574
Mar 10, 2006 07:20 AM
