Odd rich idle and cruise.
Old Apr 11, 2017 | 08:20 PM
John Ralleca's Avatar
No problem starting it up. Afr is almost steady at 10.4. Even at cruise. On a speed density tune, no boost leaks, according to my tuner o2 sensors are good, tps, map. Also asked for a rom with a stock injectors to see if my id 1000 are faulty but still the same. Tested another fpr from another evo and still the same. Im running out of ideas on what to check. Sparkplugs changed it ran good for a minute, after WOT it went back to the issue of being rich. Almost the car has no response when i was trying to get home. No CEL either.
Any help? Thanks in advance. Also my sparkplug is missing one screw on each side(valve cover stripped) , could that cause it?
Mod list: 255 walbro/ id1000 running on 92 oct.
fp green.
Last edited by John Ralleca; Apr 11, 2017 at 08:21 PM. Reason: Uncomplete sentence
Old Apr 12, 2017 | 09:50 AM
Klaiceps's Avatar
Are you running a speed density tune or do you still have the MAF?
Noticed you are from Hawaii also. Howzit and welcome!
Old Apr 12, 2017 | 12:14 PM
Aloha 😬. And yes speed density tune.
Old Apr 12, 2017 | 01:31 PM
Klaiceps's Avatar
What MAP sensor are you using? Omni 4 bar?
Old Apr 12, 2017 | 01:32 PM
Yes omni 4 bar. I tried to swap with a friend and it stayed the same.
Old Apr 12, 2017 | 01:39 PM
Klaiceps's Avatar
A few questions:
  1. What year is your Evo?
  2. I'm assuming you are using Tephra V7. Which ROM are you using?
  3. Was it running good after you got it tuned? When did it start to run funny?
  4. Any other mods?
Funny how you and I have the same injectors and turbo on our Evos.
Old Apr 12, 2017 | 01:41 PM
A few questions:
  1. What year is your Evo? 2005 evo 8
  2. I'm assuming you are using Tephra V7. Which ROM are you using? Im tuned with english racing. No tephra from what i can see.
  4. Any other mods? Yes it was running good and never had a problem after 4-5 months being tuned.
Answered^^
Old Nov 8, 2017 | 04:39 PM
nor11384's Avatar
FCOTM Winner
having the same issue did you ever figure this out...
Old Nov 8, 2017 | 09:53 PM
4b11slayer's Avatar
How old is the tune?
Have you tried swapping the intake air temp sensor?
Old Nov 9, 2017 | 07:11 AM
nor11384's Avatar
FCOTM Winner
I haven’t...how can you tell a bad iat sensor
Old Nov 9, 2017 | 11:36 AM
4b11slayer's Avatar
Measure the resistance. Across both pins. And then compare it to the gm iat resistance chart.
Resistance will correlate with a temperature.
So if its 80 degrees you need to have x amount of ohms
Old Nov 9, 2017 | 01:24 PM
nor11384's Avatar
FCOTM Winner
i got some logs...with car dead cold air temp read 68 and its in the 80s outside...dont know if thats normal...
File Type: csv
Old Nov 9, 2017 | 04:03 PM
4b11slayer's Avatar
I would try swapping the iat
Old Nov 9, 2017 | 05:53 PM
nor11384's Avatar
FCOTM Winner
but is it normal?
Old Nov 10, 2017 | 04:40 PM
RightSaid fred's Avatar
but is it normal?
It depends where you've got it mounted.
