Stupid Check Engine Light!!!!
Old Apr 5, 2004 | 09:19 PM
umiami80's Avatar
CALL BUSCHER they have a fix!!!
I did call, all they said to do was to drill a larger hole, ,which I did. They said that about 10% of the cars do not work, so I guess I am the minority.
Old Apr 5, 2004 | 09:55 PM
matt55's Avatar
I called 4/6/04 and spoke to Jarrod@Buscher and asked if they had a fix for the SES light (PO139) . He told me "yes" and i having that part shipped to me and hope to have very soon . I hope this helps you out .
Old Apr 5, 2004 | 10:06 PM
o00o's Avatar
ya i had the problem with buschur and htey told me to drill teh bigger hole but that did not work and should not have to happen, if they just stick the correct bung on the exhaust, (not the extended one) then things would be fine, so u need them to ship u a new smaller flush bung and it will clear the code, that is what i had to do after numerous times of calling and making myself get heard
Old Apr 6, 2004 | 12:05 AM
GREDDY's Avatar
I have BR's turboback. I ran catless for a couple of months without a CEL but once the temperature dropped close to 10 degrees, I got a cat efficiency code(weird!). When its warm, no codes. I'm currently running the high flow cat now and have never gotten a CEL, even in below zero weather.
Old Apr 6, 2004 | 07:51 AM
matt55's Avatar
Iam talkin about something that splices in the wireing (O2 simulator) not on the bung .
Old Apr 6, 2004 | 10:47 PM
umiami80's Avatar
They are sendin me the fix too, tanks!!!!!!!!!!!!!!!!!!!!!
Old Apr 7, 2004 | 06:04 AM
GTVEVO's Avatar
The fix they are sending you, is it the flush bung? Do you have to get it welded on?
Old Apr 7, 2004 | 06:58 AM
Jrod@Buschur's Avatar
Hey guys! Yes we do have a 02 Simulator fix for the CEL now.It gets wired into your 02 sensor wiring. If you give us a call here at the shop we can help you out with this. Thanks guys and sorry for any inconvenience this problem has caused you but we do have a fix for this now. Thanks Again!
Old Apr 7, 2004 | 08:15 AM
GTVEVO's Avatar
I tell you what guys it sure does pay to stick with quality products! I just called Buschur and they hooking me up today by sending out my o2 simulator!
Thanks a ton Buschur!
Old Apr 14, 2004 | 03:52 PM
umiami80's Avatar
Installed, and the light remains.....
Old Apr 14, 2004 | 07:23 PM
GTVEVO's Avatar
I installed mine and it took about 50 miles then zap no more light!
Old Apr 14, 2004 | 07:41 PM
992gnt's Avatar
Did you reset the ECU? There is another thread in this forum about a 'mechanical' fix for the CEL (search for spark plug and CEL). I have the Buschur TB, spent $3.69 on spark plug anti-foul adapters, 5 minutes drilling one out, and another 5 minutes installing them. The result is no more CEL after 2 weeks and 400+ miles.
Old Apr 14, 2004 | 08:17 PM
Evil_1's Avatar
Got the O2 Sim from Jarrod. Code P0420 Poofed....gone and hasn't come back. Thanks Jarrod.
Old Apr 14, 2004 | 08:54 PM
umiami80's Avatar
Naw I shut it off, and it came back On, IDK.....
Old Apr 24, 2004 | 05:29 PM
umiami80's Avatar
Today I fixed the problem, tuned out My Joe P MBC had lost its set screw leading to a nasty boost leak as well as ONLY 12 F U C K I N G PSI no clue, bought a Hallman and set it to 21, Check engine light shut off, the end....
SO FING HAPPY OMG!!!!!!!!!!!!!!!!!!!!!!!!!! NO CHECK ENGINE LIGHT, NO CAT, TAKE THAT MOTHER NATURE!!!!!!!!!!!!!!!!!!!!!!!
