Cam Gear cover bolt -- Help!
Old Jun 2, 2017 | 05:24 PM
4G63_Crazy's Avatar
5 Year Member
Hey Guys and Gals,
So I just got my new Zaklee Cam gear cover and was excited to install it... Until this happened:
(Basically as I was trying to un-do the bottom right cam gear cover bolt, the metal bent backwards and the OEM cam gear cover broke...)
Does anyone know how I can get the bolt out and fix the damage without hurting my car even more? Thanks..
Old Jun 2, 2017 | 07:07 PM
4G63_EVO's Avatar
Originally Posted by 4G63_Crazy
Hey Guys and Gals,
Woah. Never seen that before, so the bolt wont loosen?
Old Jun 2, 2017 | 07:41 PM
hutch959's Avatar
bend it back.
spray a little pb blaster on the threads.
then hold the hole thing with a crescent wrench... or something that will keep things in place as you turn the bolt.
Old Jun 3, 2017 | 11:25 AM
4G63_Crazy's Avatar
5 Year Member
Originally Posted by hutch959
bend it back.
Tried, but that bolt is on their tight! It will no come loose... Still no luck...
Old Jun 3, 2017 | 02:00 PM
4G63_EVO's Avatar
spray PB BLASTER, let it soak over night
Old Jul 4, 2017 | 01:28 PM
4b11slayer's Avatar
Euuuu imagine the under carriage
Old Jul 4, 2017 | 07:03 PM
gsrboi80's Avatar
NJ car I'd say it's pretty bad. I'd spray it with PB multiple times letting it sit a bit in between, then try again tomorrow as mentioned. If not, Order a new lower timing cover and all the bolts, snap that bit off or don't and replace with new lower and Zaklee Clear Upper Cover
Old Jul 4, 2017 | 09:40 PM
4G63_Crazy's Avatar
5 Year Member
I let the bolt soak overnight, then had mydad (strong guy) to help me.. After like 50 times of trying, he finally got it loose... God, I hate North East cars...
Old Jul 4, 2017 | 09:42 PM
4G63_Crazy's Avatar
5 Year Member
I've seen the undercarriage..... ANYTHING is more beautiful than the undercarriage... Its basically a nightmare under there... It is extremely rusty... But, atleast the body is an excellent shape!
Old Jul 5, 2017 | 04:05 PM
4b11slayer's Avatar
Ive worked on a handful of realy bad salt belt cars its a nightmare. Im in california so they are rare.
STLEVOIX
Jan 3, 2013 05:35 AM
Kevin Knight
Sep 5, 2011 02:58 PM
Gruppe-S
Aug 1, 2005 05:08 PM
