2.1L 4G64 long rod ...
A 156mm Carrillo is plenty for 9500-10000rpm. The higher you rev it the harder it is going to be to shift and keep the oil pump in it.
If you need to go past 10k I would put you into an aluminum rod. Dogbox and dry sump would also be a good idea.
What are your power goals. Going with a custom piston is a little bit more then shelf parts but you could do an offset pin to help with rod angle . Also, other piston options would net you more power.
A longer rod is going to weigh more and if you aren't going to rev it to the moon it's not needed. A Carrillo is a great lightweight steel rod , I've got a set in my engine . Easier on the bearings and less reciprocating weight. A 400-450hp turbo is going to run into back pressure long before 9K rpm.
dambikeracer
25
Sep 14, 2015 10:44 AM
evo9ben
Apr 11, 2012 02:49 PM
