Running Larger Feed Line
Old Jun 29, 2017 | 11:11 PM
WhiteHat's Avatar
Hello,
Currently trying to run a -8 fuel line from the pump to the front of the car and just wondering how others may have routed the line from on top of the drop in unit to under the car.
I can't seem to fit the line along side the OEM lines and not sure if removing the bracket that supports those would allow for enough room. (Not that its super easy to get a wrench on that nut while the tank is in the car)
Any thoughts would be much appreciated.
Thanks
Old Jun 30, 2017 | 12:09 PM
4b11slayer's Avatar
I ran a -6 and ran it along and over the hard lines on the driver side under the car and ziptied it to those hard lines. I think they are brake lines.
Tip: don't cut it until you have it all layed out.
Old Jun 30, 2017 | 05:32 PM
hutch959's Avatar
if you will unbolt the tank from the bottom, or at least loosen it, it will drop down some which will give you more room to work.
Old Jul 1, 2017 | 08:30 PM
WhiteHat's Avatar
Thanks for the replies,
I already tried running it near the hardlines but wasn't given enough room. I'll see what i can do when i drop the tank, not sure if it will be fine being so tight against the tanks outer edge though.
Old Jul 1, 2017 | 08:55 PM
4b11slayer's Avatar
Yea i dropped the tank. Not all the way. Just loosened the straps. It should be fine its usually steel braided.
BrownSuga
Sep 28, 2016 03:56 PM
evoballer
Feb 15, 2012 06:49 AM
evoforlife
Jan 27, 2011 07:06 AM
DIDYSIS
Apr 12, 2009 07:58 PM
umiami80
25
Apr 22, 2005 05:32 AM
