MANLEY prone to cracking?
480-550hp
93 until Aug 2017
Exedy twin
.... if thats the limit of a billet crank...
Hey xRoguex, how was the car driven and who build the shortblock? Also, how did you find out the crank was cracked before pulling the motor? I've been running a 100mm billet for a year now without it breaking and it has not had an easy life.
The motor was pulled because it has been using A LOT of oil lately and it was time to refresh things. It had just over 30k. on it.
Are you running the ultra light weight billet one or the standard one ? Just curious as I run the 100mm standard billet one as Tom from Tscomptuned recommended me to go that route instead when he built my engine, definitely didn’t want to run the forged unit as I have heard of it cracking.
This was the first ever billet that manley created.
The current LW version did not exist then.
There are alot of possibilities. If it was using alot of oil and oil was going into the combustion chamber that can hurt octane and cause knock. Good thing you pulled it apart to refresh /inspect things.
Did you have an aftermarket harmonic dampner ?
No.
Yeah, probably chinesium, but for cranks in general that little strip of rubber in the damper is there to absorb vibration and lessen crank metal fatigue. Overtime rubber hardens. My car is about to have its 15th birthday (please no cards) so when replacing timing belts last fall I decided to include a new damper with fresh rubber. I mention this because I suspect this is something most people would never think about.
