Carbonetics triple disk clutch issues. Please help
Old Jul 23, 2017 | 06:48 PM
moyassine's Avatar
Hello. I haven't been on here in a while, I had sold my old evo and recently picked up this gem. Any ways. The car needed a clutch when I got it. The previous owner had purchased a carbonetics triple disk clutch that needed the pull to push conversion and the Toyota bearing. I ordered the parts and tore it down Saturday night. First things first. When I installed the clutches. The basket in the middle had some okay in it. Is that usual? Couple buddy's said that's normal for triple disk. So I bolted everything up. Rotated the fork, installed the one washer that was supplied, and used the Toyota bearing. Then I installed the pull to push conversion. The main issue I'm having. I could not get the clutch to disengage in the beginning. After aloooot if adjustment I finally got it to disengage when the pedal is completely pressed to the floor and was able to put it in gear. The sec I lift off the pedal the clutchs engage. Any one had a similar issue? I put a new slave cylinder and a new master cylinder. I bled it for 2 hours straight and used 2qts of dot3 fluid.
here's how I had to modify it to get some clut h pedal.
Old Jul 23, 2017 | 08:21 PM
moyassine's Avatar
Bump anyone?
CeliOnce
Feb 15, 2017 04:56 PM
Fourdoor
38
Aug 6, 2014 05:15 AM
DFelton
14
Oct 10, 2013 08:03 PM
Wickedwhite8
Sep 20, 2011 06:39 PM
DRFTKNGG
62
Aug 27, 2008 01:14 PM
