Evo 8 Wont Start When Warm
Old Aug 19, 2017 | 01:00 PM
4b11slayer's Avatar
For now your gonna be throwing parts at it. You need to narrow it down to whats going on during the no start. I.e no spark,no/low fuel pressure
Old Aug 19, 2017 | 01:01 PM
Snowwhiteevo's Avatar
Originally Posted by 4b11slayer
Yes a fuel pump is (electric)
You're right fuel pump is less then 5 months old, but I will give it a check.
Old Aug 19, 2017 | 03:23 PM
slocho's Avatar
what he says^
buy a spark tester, they are only a few bucks and the local parts store and google how to use it, its really easy. If you have spark you can eliminate any ignition related stuff like cam/crank sensors (those both have to send a signal to the ecu for the ecu to send ignition signal to coils)
​​​​​​​if you have spark next is fuel pressure. It is very possible for a fuel pump to get warm and loose some sort of connection electrically. Some parts store will rent one to you, just make sure you have the right adaptors. Hope that helps!
Old Aug 19, 2017 | 03:27 PM
Originally Posted by slocho
what he says^
thank you guys I'll test spark tomorrow I have a fpr on the car so I can check the pressure this way.
Old Aug 19, 2017 | 05:17 PM
Thoe99's Avatar
Sounds like you need to replace the
ignition switch ignition switch
. I had the same problem before and this solved it, very common issue.
https://www.evolutionm.net/forums/ev...ied-fixed.html
Old Aug 19, 2017 | 05:30 PM
what he says^
thank you guys I just tested and I do have spark
Old Aug 19, 2017 | 05:44 PM
Originally Posted by Thoe99
Sounds like you need to replace the ignition switch. I had the same problem before and this solved it, very common issue.
car cranks and has spark but doesn't want to start. I actually just noticed that the fuel pump isn't priming when i turn it onto the on position
Old Aug 19, 2017 | 09:00 PM
4b11slayer's Avatar
These evos prime while cranking i think
Old Aug 19, 2017 | 10:31 PM
Rom's Avatar
Rom
Originally Posted by Snowwhiteevo
What would this mean it is?
So as you see the car wont start when warmed up. The car has no issue when it is cold starting. Yesterday when I was driving to work the car started acting weird then the RPMs were jumping and heard two backfires from the exhaust, so I pushed in the clutch then the car died and would not start again. I had to have the car towed home and when I got home of course it started straight up. I have already tried swapping out the map sensor with another friends 4 bar same brand and nothing. I have also read on here that someone else was having the same issue with theirs and they replaced the cam position sensor, so we also tried this and nothing car still wouldn't start when warm. I messaged my tuner and he said it sounds like a leaky injector, but idk if this would be the case as the injectors are less than a year old but who knows. I am on speed density and on E85 if this helps. Stock ECU. any help would be gladly appreciated.
Petty common that this is either crank position or camshaft position sensor. I had it on my Porsche - exact same symptoms. I also saw an Evo thread where it was the camshaft sensor.
Thanks!
S.
Old Aug 20, 2017 | 11:59 PM
barneyb's Avatar
Thanks!
S.
So, repeat the spark test when it refuses to start.
Old Aug 21, 2017 | 12:43 AM
RightSaid fred's Avatar
You've probably got the "deleted the FPR solenoid" on your mod list.
That won't help.
Probably got a whole load of other things wrong too.
Checking the fuel pressure is always a good start because it's nearly always wrong.
Old Aug 21, 2017 | 12:50 AM
mines5's Avatar
Did you just recently downloaded V7 and flashed it. All this started happening after that ?
Which injectors are you using ?
Old Aug 21, 2017 | 03:32 AM
I've check the spark when the car does not want to start it does spark. And also I am running 2150s the car has been running fine on this fine for 5 months now With no issues prior to this.
Old Aug 21, 2017 | 08:06 AM
slocho's Avatar
with good fuel pressure and good spark, its most likley not opening injectors. I cant imagine your car loosing that much compresson only when warm, or loosing compression at all. With good compression, fuel, and the right timing it has to start, being that it starts when cold my guess is timing is correct. I dont know much about tuning but it sounds like something electrical causing the injectors not to be fired off.
​​​​​​​have you tried squirting some brake clean in a vacuum port while cranking? Its not a very recommended test but if your car is not getting fuel, itll run with break cleaner as a fuel source. Ive done it before but only for a few seconds to confirm it runs.
Old Aug 21, 2017 | 08:10 AM
i haven't tried this yet but fuel pressure is around 30 when cranking and mid 40s while running. Fuel pressure is still good from what I remember when the car will not start . Is there anyway to post videos in here?
