Evo 8 Wont Start When Warm
Old Aug 21, 2017 | 08:56 AM
  #31
mines5's Avatar
Flash another rom and try ..
Old Aug 21, 2017 | 09:00 AM
  #32
Snowwhiteevo's Avatar
Tried this tried to start it on 93 map.
Old Aug 21, 2017 | 09:19 AM
  #33
mines5's Avatar
What was the result?
Old Aug 21, 2017 | 01:10 PM
  #34
Still won't start with change of map
Old Aug 24, 2017 | 12:49 PM
  #35
bump.
Old Aug 25, 2017 | 10:37 AM
  #36
mines5's Avatar
Try swapping or changing your Coolant temp sensor or check its connection and wires.
Can you turn off CL and tune it in OL for idle n cruise and then try starting it up when warm ?
Old Oct 28, 2017 | 03:08 PM
  #37
BUMP
The car is still having this issue, and now that I think of it it started when I was changing my oil and had my car jacked up. I got done and noticed that the wire from the fuel pump to the battery was hanging a little so I moved it up and ever since this the car will not start when hot I have proper fuel pressure, but something that has recently started happening is the car is getting really rich while driving and pressing on the gas at all AFR goes to 10s "maybe lower my gauge only goes to 10.0." With this I was sure it was the coolant sensor, so I went and bought both new OEM Coolant sensors thinking this would fix the issue yet I was wrong. The car will still not start when warm and car is undrivable as the AFR goes way to low when giving it any gas making it really stuttery.
Any help would be greatly appreciated. Also to throw in the fuel pump and injectors are less than a year old.
Old Jul 23, 2025 | 09:11 AM
  #38
Rubythecherry's Avatar
Originally Posted by Snowwhiteevo
BUMP
Did you ever manage to fix this?
URNVS
Jul 16, 2014 01:48 PM
EriCS
10
Feb 12, 2009 08:05 PM
WongFu
AEM EMS
10
Nov 29, 2007 01:28 PM
LarryMags
Jan 11, 2007 06:53 PM
