A couple beginner questions about air/fuel ratios
So im just starting to teach myself about tuning.
Here is a couple questions. If you have any links or reading material recommendations associated with these questions I would welcome that.
If your running 8psi, and you turn your boost tap up so your running 15psi, will this change your air/fuel ratio while under boost?
my uneducated guess was the ecu would pump more fuel to keep the set air/fuel mix, and the limit would be the ecu mapping or the type of injectors and fuel pump.
Does your air fuel ratio change while under boost? explain in depth why or why not.
I need to learn more about ecu, mapping and air fuel.... please link me
thanks
thanks
thanks
thanks
deadbeatrec
90
Jul 29, 2010 11:44 AM
BigValley
Evo 'For Sale' Electronics / Lighting / Audio
48
Dec 22, 2008 10:07 AM
iTune
26
Apr 25, 2007 07:54 PM
trinydex
Jul 10, 2006 05:00 PM
