Does it sound like a bad MAF sensor?
Hello guys im having an idle and throttle tip in misfire only and unstable idl afr ,swings to 12 then 17 then normal every now and then, cruise afr are on spot no misfires and on wot is good .on idle i cant push the throttle all the way down instantly the car will act as if theres no fuel in it but if i go smoothly it will go all the way to redline its annoying .No vacuum leaks ,changed plugs, does it sound like a bad MAF sensor ?
When my maf was bad, i had a weird idle, and some stuttering driving, felt pretty good at WOT but then started to dump fuel. How is your ICV? Do you know if it actuates? How about your TB? do you know how well that is sealed? These are issues I had with getting my car to run right. The omni 4 bar is like $100 on MAP, and its just a small sensor and quite expensive, but it solved my issues right away
Do you have evo scan? You can go into evo scan and watch values while idleing and it makes diagnosing the issue easy
Im on SD, but when the car had a bad MAP sensor it went quite a while before the car got bad enough to throw a code (the car died when i was at a stoplight, luckily limped it to work). I had been chasing the MAP sensor for a couple months before I found it. evo scan is the way to go
Danny23
11
Oct 1, 2006 04:09 AM
smokedmustang
14
Jan 6, 2006 10:42 AM
