Flywheel Mounting Flange Damage On Crank
Old Oct 29, 2017 | 12:19 AM
Doctro X's Avatar
so i started hearing weird noises from my gearbox and the gears was not going in . Removed the gearbox to inspect and found my flywheel bolts slack . Upon further inspecting , after removing the flywheel , i saw some arc marks on the flywheel and the mounting flange on the crank .
I am wondering if i should be worried and just have the flywheel face polished or should i replace flywheel and crankshaft ?
Flywheel Mounting Flange Damage On Crank-123-1-.jpgFlywheel Mounting Flange Damage On Crank-1234.jpg
Old Oct 29, 2017 | 09:43 PM
LetsGetThisDone's Avatar
Post pics of how bad it is? Most of the times this happens the crank is junk.
Old Oct 29, 2017 | 11:35 PM
4b11slayer's Avatar
As long as you can bolt the flywheel in and it allows proper torque and it sits flush i dont see a crank replacement.
Old Oct 30, 2017 | 10:02 PM
Doctro X's Avatar
pics inserted ...
Old Oct 31, 2017 | 07:50 AM
4b11slayer's Avatar
Ouch. I would just attempt to smooth out the rough areas and keep on trucking
Old Oct 31, 2017 | 09:27 AM
Nope, crank is done. You can have it repaired (needs to be removed from the engine), oe pick up a new one.
Old Oct 31, 2017 | 01:09 PM
RightSaid fred's Avatar
Bolt it back together, torque it up.......measure runout with a dial gauge.
The spec is in the manual somewhere.
If it's within spec and there's no cracks or anything silly.....it's OK.
heyythurr
Nov 3, 2014 11:52 AM
_des_
Mar 8, 2012 07:56 PM
hybrids14
Mar 19, 2007 01:06 PM
Gruppe-S
Evo 'For Sale' Engine Internals and Drivetrain
19
Feb 16, 2007 12:15 PM
SOF
Feb 19, 2006 08:06 PM
