Delete ACD pump and work the transfer without oils
Old Oct 29, 2017 | 09:13 AM
GreeceS13's Avatar
How can I convert a ACD transfer to non ACD? I dont meam to change transfer.. just to delete pumps and make the transfer to work like mechanic! For drag use only.
Old Oct 29, 2017 | 01:30 PM
GreeceS13's Avatar
Anyone?
Old Oct 29, 2017 | 02:51 PM
kikiturbo's Avatar
if you remove the pump you will still have 4 wheel drive but without the central diff lock... You could theoretically just put some sort of air reservoar on the ACD line and pressurise it to 16 bar to keep the central diff lock more or less locked.. that could work for drag.. (if you do not want to take the transfer case off and change it for non acd transfer..)
Old Oct 31, 2017 | 08:59 AM
GreeceS13's Avatar
Thanks!
Do you know 16 bar what lock will produce? I heared to put around 3bar air.
Old Oct 31, 2017 | 10:38 AM
kikiturbo's Avatar
16 bar is max pump output, however I doubt it is max pressure that goes out of solenoid... yeah, start with 3 or 5 bar..
Old Oct 31, 2017 | 11:57 AM
GreeceS13's Avatar
What is changing exactly as the pressure is going more and more?
NOMIEZVR4
Oct 18, 2013 01:28 PM
nlp187
Jul 8, 2012 10:32 PM
HybridKOOP
Evo X How Tos / Installations
28
Dec 7, 2010 02:16 PM
k270kmh
Aug 6, 2007 02:39 PM
