Competition twin disk vs Exedy twin.
I have looked and read, most of what i found is older. I am about to pull the trigger on a twin disk. I have always thought the Exedy twin is the clutch to pick. I saw that Comp Clutch twin disk comes with everything to go from Pull to push. and they also say holds more power. All for the same price or is it smart to just stick with Exedy?
Comp makes great products. I've got their stage 4 clutch and love it. Holds back to back to back to back to back to back to back to back passes with 6k launches at the dragstrip without issue. I was going to get their twin disk but don't have the room to fit the bracket to flip the slave cylinder with how my hot side intercooler pipe is routed.
Honestly, you can't go wrong with either. Also, if you are dailying it you may want to consider a single disk clutch as twins and triples aren't the most daily friendly clutches.
If you end up getting the exedy be sure to get an ACT monoloc and a clutch fork stop.
Illrunya
Jun 14, 2015 08:10 PM
FS[Northeast]: Exedy Twin Disk HD guys! BNIB Exedy HD Twin Disk REBUILD KIT
Illrunya
Northeast Region
Jun 9, 2015 12:56 PM
EvowagonIX
Mar 31, 2015 04:40 AM
Nomad4g63
Apr 14, 2009 08:34 PM
