Best way to hit 400whp in evo 8
I want to know what I should do to be able to hit 400whp, i'm looking to use this as my daily and street car. it would be great if i could get a list of previous builds that hit this including internals. not trying to blow it sky high, thank you
I can only speak from my experience but i have reached 400hp on a stock block, BBK lite, RC1200 injectors, AEM 320 fuel pump, GSC s1, mil-spec 100 cell high-flow cat, RRE 3 port boost controller, Turbosmart Evo 9 internal waste-gate, RRE 3" cat-back, random 3" downpipe, and a buscher street FMIC. Granted all these parts combined with a solid tune on e-85 got me to 400. I'm fortunate to have an e-85 station near by allowing me to daily on it. The power levels you seek are attainable with a Evo 9 turbo. What do you have in your Evo? Rather than recommend parts it's best to know what you are working with.
The biggest deciding factor here is whether or not you have access to e85? If you do getting to 400whp is very straight forward and if not youre looking at upgrading your turbo at the very least.
Simple as this:
- Cams (GSC S2s or any 272s and upgraded valve springs if you want 400whp)
- Turbo-Back Exhaust (Downpipe, Testpipe/ HFC, If you have the money ported o2 housing or dump)
- Intake
- 3.0"+ FMIC, LICP
- Fuel Pump (255 walbro or higher)
- 800cc+ injectors
- Evo 9 BOV or something other than the 8 BOV (since they are crap and leak)
- New Tune and E85
- Head Studs
I basically have all of these, but not E85 and I have GS1 cams
Im making 331awhp - With E85 and higher HP rated cams you'll be somewhere around 400whp.. (And depending on your budget, an evo 9 turbo or an HTA71 will boost you HP too
- Intake
- 3.0"+ FMIC, LICP
- 800cc+ injectors
- New Tune and E85
- Head Studs
valve springs on 272 and anythimg smaller tham a green is not really needed
wont be going over 7500 rpm
cams
lico
e9 bov
down pipe
o2 side weather its dump or regular
bigger injector
fuel pump
intake and uicp optional
cams
lico
e9 bov
down pipe
bigger injector
fuel pump
im making 400/350 right now on 91 oct
fp red jb with mhi housing
fp ported manifold/ported turbine housing
ets 3.5 in intercooler/ stock route piping
hks 272 cams
id1000s
walbro 255
megan downpipe
buscher catback/test pipe
tuned at 27lbs of boost
hks 272 cams
id1000s
walbro 255
megan downpipe
seahawks12th
41
Jun 15, 2009 01:05 PM
NocturnalEVO
59
May 1, 2005 10:15 PM
