Missing a Bolt on the Engine Block for the Inspection Hole
Old Dec 16, 2017 | 06:44 PM
deylag's Avatar
I was removing my timing belt today and I noticed that the inspection hole at the front of the block for the balance shaft is missing its bolt. I can only guess that since this is my first time doing the timing belt that the previous mechanic did not replace the bolt.
My Evo has experienced a couple track days and dyno tunes since the last mechanic worked on the timing belt. That hole has been open to exhaust heat and any number of contaminants.
How screwed am I?
Old Dec 16, 2017 | 07:42 PM
barneyb's Avatar
I'm surprised it didn't lose oil. Anyway, spilt milk but I doubt it is a problem.
Old Dec 16, 2017 | 07:45 PM
Just making sure youre referring to the port used to align the balance shaft?
If that port is open to the crank case, then a simple oil change would be best
Old Dec 16, 2017 | 10:00 PM
deylag's Avatar
Yes that is the port I am describing.
Old Dec 17, 2017 | 01:27 PM
kaj's Avatar
kaj
Oil change, just in case. Trim down a standard bolt to fit (IIRC, it needs to be really short). Done. I, too, am surprised it didn't get too messy. I'd expect a lot of oil to shoot out of there LOL.
Good thing you found it sooner than later!
Old Dec 17, 2017 | 01:57 PM
4b11slayer's Avatar
Balance shaft inspection hole. Were they ad a breather line. It wont spit out oil. Unless you have alot of crankcase pressure.
Blue91lx
37
Apr 9, 2015 06:07 PM
ch53avitech
Jan 19, 2015 07:16 PM
MacMan
30
Feb 14, 2014 05:53 AM
Blue91lx
10
Jun 27, 2012 12:33 PM
omniprobe
Aug 8, 2010 11:48 AM
