exedy twin: check the inspection hole. is this normal?
Old Aug 6, 2010 | 12:06 PM
omniprobe's Avatar
I check the inspection hole and see the fingers pulling but I can see those wavy o rings sort of just siting there. I thought they were suppose to help lock the throw out bearing to the clutch. if so I have yet to see them be pushed into the clutch by the throw out bearing
Old Aug 7, 2010 | 04:15 PM
omniprobe's Avatar
bump for an answer
Old Aug 7, 2010 | 05:26 PM
ACTman's Avatar
The wave washers only compress when you are disconnecting the release bearing from the pressure plate.
Old Aug 8, 2010 | 06:17 AM
omniprobe's Avatar
So are you saying it's normal to see the wave washers then? The clutch pedal was pushed and released while I looked and It never went out of sight.
Old Aug 8, 2010 | 11:48 AM
ronmaster901's Avatar
You have to be able to see the wavey rings because you have to wegde a screw driver between them (wedge collar) and the tob in order to dislodge it i thought...idk i dont have much experience with exedy twin set ups.
My only experience is with an exedy stock replacement clutch. I did it in my driveway (a nightmare of course). no lift, no engine hoist, just jack stands and man power. From what i saw, you always can see the wavey rings and the only time that they compress is when you are prying the clutch fork toward the drivers side pressing the TOB toward the pressure plate. The only time you want to do this is when (like omniprobe said) you are disconnected the TOB from the pressure plate via breaking the wedge collar free.
Other than that, the purpose they serve is to have pressure on the wegde collar ring and the pressure plate to hold the wedge collar assy in place. My info is based on my driveway experience so anyone feel free to correct any misleading information please.
anthonyt09
Apr 28, 2016 08:26 PM
wazmunstr
24
Nov 29, 2010 06:06 PM
GrimCreaper
Apr 12, 2010 08:52 PM
fyreant
Nov 5, 2009 04:11 PM
AtticusDemon
18
Oct 10, 2009 08:32 PM
