Stuck TOB
Old May 23, 2009 | 11:38 PM
AtticusDemon's Avatar
Stuck TOB
I'm currently doing a clutch job and I'm at the point where you stick a screwdriver into the inspection hole to pop off the throw out bearing. The problem is it will not pop off no matter what I try.
Does anyone have a "Plan B" for how to get the TOB off?
Old May 24, 2009 | 08:20 AM
MR_Evo_Rob's Avatar
You really just have to work at it. As your turn the flathead, slowly release the arm so it comes back as you're releasing the TOB. It took me about 30 minutes to finally get it off.
Practice with your new pressure plate and TOB.
Old May 24, 2009 | 08:41 AM
YellowEvilEvo's Avatar
I had the same problem. The problem is that if whomever did the previous install did not use an OEM TOB. The OEM TB has an internal sleeve that prevents it from sticking to the shaft. I ended up having to unbolt the PP...and cut the damn thing off....
Old May 24, 2009 | 10:35 AM
MR_Evo_Rob's Avatar
Thats why I used the OEM TOB
Old May 24, 2009 | 12:04 PM
dueces's Avatar
If you rotated the crank, you can unbolt the pressure plate one bolt at a time, there are six i believe, then you just take the tranny out with the pressure plate to get at it with the tranny removed..... Right now I have an aftermarket TOB and Some time it's REAL hard to get my tranny into gear when I start my car! Stick with an OEM piece.
John
Old May 24, 2009 | 12:32 PM
33bull's Avatar
x2 i just had this happen to me this week with the act wedge color
Old May 24, 2009 | 12:42 PM
Thanks for your input everyone, I will have to give it another go on monday. I used the OEM TOB with the exedy twin disc.
Old May 24, 2009 | 02:01 PM
FX11's Avatar
+1 on that
you can remove the tranny with the pressure plate
you can deal with it from there
i also cut the PP off, if you want pics let me know
Old May 24, 2009 | 02:06 PM
alloutDSM's Avatar
GL mine was in shreds getting it out lulz
Old May 25, 2009 | 09:44 AM
Evoryder's Avatar
getting a bigger flat head with more leverage
Old May 25, 2009 | 10:15 AM
dsmfan95's Avatar
John
This is what we had to do.
Old Oct 5, 2009 | 12:46 PM
evo panda's Avatar
how did you able to cut off your tob. i am having the same issue?
Old Oct 5, 2009 | 02:57 PM
bmxer4it's Avatar
if you cant get the TOB off in the first couple tries... its not comin off. Dueces has it right... rotate the crank and feel for the 6 bolts... you have to feel throught the small service hole in the tranny. it takes a second to find the best way of doing it, but once you know how... you can have the whole thing off in less than 20 mins. hope it works out for ya.
Old Oct 5, 2009 | 03:07 PM
KevinD's Avatar
or, in 90% of the times i cant get the TOB off just by turning the screwdriver, i stick the screwdriver in, and rotate the crank at the same time as i twist the screw driver. usually 1-2 revolutions of the crank and the TOB pops loose. the other 10% the PP has to be unbolted.
1. pull back clutch fork
2. insert screwdriver between TOB and retainer
3. turn screwdriver while gently releasing the clutch fork
4. with screw driver twisted, either the TOB will come loose and clutch for will release all the way to passenger side of hole or:
5. keep screwdriver twisted
6. rotate crank over until TOB releases
Old Oct 5, 2009 | 03:11 PM
debotheevo's Avatar
try different angles!
