Coil or cam position sensor?
Old Dec 17, 2017 | 05:56 AM
meckert's Avatar
Have had an intermittent miss, started as a stumble on acceleration and then moved to be persistent miss. Tracked it back to #1 coil-- plug was black all others in good condition. Tested spark on all coils 2 and 4 had a good hot spark, 1 and 3 had spark but seemed to be not as hot. Anyway changed the coil on number 1 fired it up. Seemed to run smooth--took it out and under any load the miss was worse than before--almost like 2 cylinder are out. Have a coil on plug sparktech set up on Evo VIII. Have read that Cam position sensor cam cause this? Anyone have a definitive solution-- I dont like to change parts for the sake of it.. ( already changed plugs running .022gap)
Old Dec 17, 2017 | 03:04 PM
4b11slayer's Avatar
Compression test
Old Dec 18, 2017 | 11:29 AM
meckert's Avatar
Thx, cps did the trick-- compression is fine.
DOUGLAS
Feb 16, 2009 05:35 PM
Turbotsiawd96
Oct 31, 2006 08:43 AM
EVOVII_SWE
Sep 9, 2004 02:02 PM
91_LaserRS
Aug 13, 2004 07:34 AM
AvatarOfWar
Aug 31, 2003 06:39 AM
