Valve cover baffles
Old Dec 18, 2017 | 07:18 PM
SDevol8's Avatar
Valve cover baffles
Are the baffles in the valve cover needed? Im going with a vented catch can and the valve cover has no baffles. Only problems I see is the catch can fikking up quick but if I install a kiggly hla would it help
Old Dec 18, 2017 | 07:21 PM
Abacus's Avatar
For a street car Yes. If it were a drag only car with a dry sump you wouldn't be concerned with them
Mitsubishi designed and built a great platform that you don't have to try and re-engineer the wheel.
Old Dec 18, 2017 | 10:02 PM
LetsGetThisDone's Avatar
If the car gets driven more than a 1/4 mike at a time, you need the baffles in the valve cover
Old Dec 19, 2017 | 05:25 PM
hutch959's Avatar
if you take the baffles out... ALOT of oil will make its way out the vents.
so the general answer is YES. they are needed.
420a-t
27
Aug 1, 2023 09:27 AM
Graphic
May 21, 2015 04:48 PM
05ah8james
20
Mar 20, 2014 11:33 AM
skatermsmn
22
Mar 28, 2013 03:24 PM
anthonyrb98
Aug 10, 2011 01:01 PM
