Next 3 gauges for Evo
Old Dec 19, 2017 | 08:22 AM
McRooster's Avatar
Hi guys,
I am planning to get a 3 gauge pillar mount and will be adding an extra 3 gauges. I already have a wide band + boost gauge.
I understand oil pressure is super important which is on the list, what other 2 gauges should I get along with it. As for readings how far should the gauges go, the oil pressure one I am planning to get is 0-200 PSI or is something like 0-150/0-100 enough?
Old Dec 19, 2017 | 01:38 PM
GeminiEvo's Avatar
Clock and volt meter, JK. Unless you track your car a lot you only really need a wideband and boost gauge. If you're looking to add I would do oil pressure, oil temp and take your pick for the 3rd one.
Old Dec 19, 2017 | 01:47 PM
Pal215's Avatar
Originally Posted by McRooster
Hi guys,
I've never seen anything over 125psi in my own car for oil pressure when it's cold and High so a 0 - 150psi oil pressure gauge should be enough. You already have the two other important gauges (boost and wideband). Next I would add EGT and and possibly oil temp, but that would be it. I personally run a voltage gauge connected to my fuel pump. It has proved to be useful for me. A voltage gauge to the battery won't tell you about the voltage drop the fuel pump sees no matter how well you have it wired.
Old Dec 19, 2017 | 02:59 PM
LetsGetThisDone's Avatar
Oil pressure, oil temp, and water temp.
Old Dec 19, 2017 | 05:23 PM
hutch959's Avatar
fuel pressure is nice to have.
Old Dec 19, 2017 | 07:27 PM
McRooster's Avatar
Has anyone used Innovate gauges before, this one is a 2 in 1 for the oil pressure/temp and is a good price.
http://www.innovatemotorsports.com/p.../MTXD.php#3852
Fuel pressure sounds like a good idea.
Old Dec 19, 2017 | 10:02 PM
codgi's Avatar
Oli Pressure no matter what. Oil temp and fuel pressure if you also track the car. If you do fuel pressure just like oil pressure you'll want to get a gauge with a wide enough range. Not near my car or I'd check the range for you.
Old Dec 19, 2017 | 10:05 PM
Evo9_Dubai's Avatar
Fuel pressure saved me tons of guess work when facing fuel problems.
Old Dec 20, 2017 | 05:50 PM
WRC-LVR's Avatar
I have boost and Wideband, EGT, Oil pressure and Water temp.
Be aware that a 3 pod pillar will block the use of the sun visor. Mine did and I had to remove it
Currently use a custom 2 gauge setup on the steering that DOESNT block any view of the main Mitsu gauges. Plus 3 in the center on Autometer panel with my stereo down below.
Old Dec 22, 2017 | 03:14 AM
McRooster's Avatar
For the fuel pressure/oil pressure I understand with these they require oil lines going to the gauge? I'd rather not have hot oil running through my cabin, would it be better to get a digital/air-core one? Is this also the same with oil temp?
EDIT: Also is an aftermarket fuel rail required for fuel pressure gauges?
Old Dec 22, 2017 | 08:24 AM
electronic sensors are better. It makes the pressure gauges more expensive, but it's worth it.
Maximum404
Future Lancer / Evo Models
Jun 11, 2010 11:04 AM
importdps
Evo 'For Sale' Electronics / Lighting / Audio
54
Jan 3, 2009 08:10 AM
2befast
Sep 7, 2004 10:37 PM
