Evo 9 No start after parked for 10 months
Old Dec 24, 2017 | 06:02 PM
EvoRix's Avatar
Parked my Evo in the garage for 10 months. Back in July I started it up and took it for a 15 mins the car started up fine. Recharged the battery and went to start it last week, only cranks but won’t start up. When I cranked, the tachometer didn’t move at all. Removed the plug, was cold and no smell of gas. After multiple attempts, I get a CEL: p0335 (crankshaft position fault). Car has 130k. Is it likely the crankshaft sensor because other members on the forum said a cam sensor failure triggers similar symptom. Thanks
Old Dec 25, 2017 | 04:43 PM
hutch959's Avatar
any spark?
Old Dec 25, 2017 | 06:42 PM
EvoRix's Avatar
I held the spark plug close to ground and had a friend crank, didn’t see any spark.
Old Dec 25, 2017 | 08:09 PM
mt057's Avatar
Have you had the battery tested?
Old Dec 25, 2017 | 11:07 PM
EvoRix's Avatar
A new Odyssey CP680 battery was put in prior to storing the car in the garage 10 months ago. When Park, the leads were taken off the terminals and a fresh charge prior to starting the car.
If crankshaft position sensor is bad, would I get a voltage signal when cranking? I was reading 8-9 volts when cranking at the fuel pump.
Old Dec 26, 2017 | 10:26 AM
barneyb's Avatar
The answer, at least on a stock car, is no.
Old Dec 26, 2017 | 02:21 PM
fafaforza's Avatar
So the battery sat for 10 months, discharging. I'd have it tested, or try to jump the car. You don't recharge a car battery the way you recharge your laptop. They're not meant to discharge and stay discharged for long periods.
Almost Ford
Feb 2, 2018 04:48 AM
camMCLEAN
Jun 4, 2008 12:10 PM
blakevo8
Nov 7, 2005 07:24 PM
superz
Jan 10, 2003 12:58 PM
