Balance shaft delete rubbing?
Old Dec 26, 2017 | 06:17 PM
botemarc's Avatar
Damn screw! Will replace it with an Allen head screw
Noticed it when I remove the oil pump casing. Has anyone ever seen this before? What could have caused this? Should I reuse it or replace?
oil pump looks good. Even inside the block where the bearing sits looks ok. I just need some assurance that this is ok or should I replace the Balance shaft delete?
thanks for your input!
Old Dec 27, 2017 | 07:35 AM
botemarc's Avatar
bump....anyone seen this before?
Old Jan 3, 2018 | 03:52 PM
Pal215's Avatar
Are you referring to the marks left on the front case inside the oil pump housing? I've seen that before in a few builds and decided that it's normal wear and tear.
Doesn't that damn philips head screw suck? I also had to use an impact screw driver to remove it haha.
Old Jan 3, 2018 | 05:14 PM
botemarc's Avatar
No. I’m referring to the rub mark at the head tip of the actual shaft that goes inside the block that sits and spin in the bearing. I marked it in this picture.
Attached Thumbnails Balance shaft delete rubbing?-1bd4c972-215f-4466-9f41-2bbff9034621.jpeg
Old Jan 4, 2018 | 04:00 AM
Wheelie's Avatar
It's just left over forging that didn't clean up from the turning operation.
This is the picture for the GSC Race Balance Shaft off the LancerShop website.
Old Jan 4, 2018 | 04:10 AM
Project_Broke's Avatar
^ This.
Old Jan 4, 2018 | 04:39 AM
botemarc's Avatar
Thanks for that info...looks like you're right! Peace of mind..
The question is do I just keep this or go with the stubby short balance shafts?
Evo47
Feb 8, 2017 01:51 AM
nlp187
Jul 8, 2012 10:32 PM
Anarchy99
11
Mar 7, 2012 12:17 PM
sterdyevo
12
Dec 8, 2007 12:08 PM
